How to measure minimum disctance between parts in assembly
Hello It is very difficult to measure the minimum disctance between parts in assembly. We are using ProE too. Pair clearance option in ProE which provides to measure min and max distance between the parts. Is there any option in solid edge ST4.? Venny
Re: How to measure minimum disctance between parts in assembly
Yup, there's an imaginatively named function called Minimum Distance - look in the Inspect ribbon tab in the 3D measure group.  You can set the filter to pick lines, edges, faces or bodies.  THere's also a minimum distance option within the smart Measure function (just called Measure)
