How to pattern part within an assembly without creating a pattern?
How can i pattern/copy a part within an assembly without creating a pattern?
I need to pattern a part multiple times with a fixed distance between each along x-axis
My old CAD program I just select the the part, define the axis and then type how many copies I want with XX distance between each. Something similar in SE?
Betreff: How to pattern part within an assembly without creating a pattern?
Hi @Maskinbyggerne
Just use a Pattern Along Curve!
Select the parts, start the pattern feature, an edge (axis), number and distance.
Result should be what You expect it to be.
Perfect Smiley Happy
How do you edit an existing pattern? I do not see it in the "Tree menu" with my parts etc.
Hi @Maskinbyggerne
take a look onto the bottom lines of the pathfinder.
Patterns normally a shown as extra group at the end of the pathfinder.
@hawcad  schrieb:
Hi @Maskinbyggerne
... to be correct:  Assembly Patterns!
Perfect, found it - no idea why I missed that in the first place Smiley Happy
Thanks again for helping.
Hi @Maskinbyggerne
welcome, I'm happy being able to help!
