How-to question sync part
Any tips on how to copy the feature as shown in video?
(view in My Videos)
Re: How-to question sync part
Just select more faces. The big flat faces.
Select enough to cap off the feature and the software will trim away the rest.
LMGi
www.TLMGi.com
I tried that but it didn't seem to work. The long faces were copied as surfaces along with the knuckle.
Hello Bruce,
normally it's not so hard to copy features. If you add two faces and stitch them with the copied faces you can add this to your modell.
(view in My Videos)
Greetings from Germany
Christian Kunkel
https://c-k-m.info
Hi my Friend,
You need for two small faces what will be connected to "hinge's body".
Here is a video about steps:
BR,
Imics
@ckunkel72 you were faster than me! Smiley Wink Great job!
BR,
Imics
I also was slow. :-)
But I share my video from ST8
(view in My Videos)
ST8.
Tibor
Thanks everyone. After @JasonTitcomb's response and my return response of confusion I had a "duh" moment and realized I was neglecting to select the face behind. When I did that it worked. But it was at the end of the day yesterday so I couldn't try it until this morning. The method I used didn't require any stitching. I just selected all the connecting faces per Jason's recommendation. But I'm going to practice the stitching method too.
@Imics, I'm going to have to study your method a bit. Pretty involved and there's the language thing. The method I used was very straightforward but your "advanced" techniques might serve for more complicated situations.
Thanks again for all your help.
