How to remove an Old Template?
Not applicable
Is there an easy way to remove a basis/template reference from the drawings?
Quite embarassing, I was doing a drawing for one supplier, but we've actually taken
the work to their rivals.
I changed the boarders manually, but the document still contains the original companies
name on the "File>Properties>Summary" page (in JPG).
Can I remove this name?
-Andy.
www.continual-motion.com
Re: How to remove an Old Template?
Not applicable
Andy,
I don't know of a way to clear this, but you can fake it out.
Save the draft file to your template folder. Give it a unique name and don't
override your existing templates. Create a new draft file using this file as
your template. You will get an exact copy of the file with the template
property changed.
Rick B.
Not applicable
Quick, dirty, and a success - I like your thinking sir!
-Andy.
"Rick B." wrote:
>Andy,
>as
>property changed.
>Rick B.
