How to scale from 2D
I'm doing full scale layout of our truss manufacturing plant.  It is drawn in full scale on 2D Model. When can I apply text and dimensions to various machines, building dimensions, etc.
Re: How to scale from 2D
Hi there,
If you then insert working sheets as desired, and run the "2D Model" command again, from the sheet you want to place view[s] in,....then that view can be scaled & annotations added as you need.
Solid Edge ST10 [MP8] Classic [x2 seats]
