How to set Liner round off in Cut Length Values in Parts List?
Does anyone konw if it is possible to do this, i have the porperty text set to Total Length but need to show to nearest mm not 2dp.
Consultant - Design Majenta PLM - ST10/MP03
Re: How to set Liner round off in Cut Length Values in Parts List?
Community Manager
Yes. Search "format codes" in the help. It covers this and more...
Dan Staples
Thanks Perfect, Template Updated, sorry for the double Barrell here but would you also know how the codes for the property text to get into reports, this is a 4 digit number, we use Frame for some pipe routing (wrong i know) and would like to be able to find the flat length without going to a drawing and using parts list command.  So trying to customise the BOM report (tools) to show the length, it currently has 1402 as document number,  1102 as title.  If this is not possible are there other options to finds this length,
The format code is /@x where x can be 0..3... what you need for.
To get cut length in ST6 is hard thing (in 3D), but it will be very, very simple in ST7. The new Measure command will provide this function and you can save the results in the Variable table. Nice!
Here is a video (what try to represent yout workflow):
BR,
Imics
