How to show parametric dual dimensions in hole table
I am trying to create a hole table having dual dimensions. Struggling to attach parametric dual dimensions for hole sizes as well as for its position dimensions. currently I have provided dula dimension for hole size using  "Note and Tolerance" but it's unparametric and will not update if hole size get updated. Haven't found a way to add dual dimension for X and Y so inch dimensions are blank in below table. Please let me know if someone has solution to show hole table with dual dimensions. hole table.JPG
Thanks in advance !
