How to split quantities in part list in 3D assembly (using auto part list)
22 REPLIES 22
Re: How to split quantities in part list in 3D assembly (using auto part list)
Hi @Naveen10
Could you be more specific please?
(I presume you mention about draft environment and creating part list table ?)
Arek
Actually I used the same components in the assembly, in auto BOM it showing the qty. 2Nos. but I want split as 1qty. in separate because both have different material.
NOTE : we had libaries, thoese doesn't contains the materila specifications.
Hi @Naveen10
I created the simple ASY using the same file name for 2 different parts, but with different material.
Try to play with your properties settings.
Arek
Hi Arek,
Thanks a million for your solution.
Thing is I cannot specified the material in the standard library..
We are using teamcenter standard drawings are released on teamcenter
.so I can't modify drawings.
Is there any other idea to split the BOM.
@Naveen10 I guess it's arguable if it's the same part if there's different materials, but assuming that's what you want to do, i'd look in to custom occurence properties. You could create one called Material that you assign per item in the assembly. You can then call this out on drafts AFAIK.
Plus I believe, though I haven't tried it, that you can sync these to Teamcenter as of ST10.
https://docs.plm.automation.siemens.com/tdoc/se/109/se_help/#uidSmiley Tonguertprp1a
@arekkulHow did you do that? One a .par file the other a .psm?
Solid Edge 2019
Windows 7 Professional
Nvidia K2200 & Intel Xeon
"You're doing it wrong"
Hi @nominus38,
I created two parts with the same file name (but different material properties), but each one was saved in different directories.
After this I created ASY.
Arek
Why does mine always yell at me if I try to bring two parts with the same filename into the same assembly then? Mine won't allow me to do that. Unless, were both of the parts in different directories from the assembly?
Solid Edge 2019
Honored Contributor
Honored Contributor
The combination of file name and file location must be unique for every part.
