How to turn Attribute Mapping in Solid Edge OFF
Hi Everybody,
I would appreciate it if you would tell me how can I turn the Atrribute Mapping off in Solid Edge.
Thanks in Advance!
Re: How to turn Attribute Mapping in Solid Edge OFF
more detail please?
are you refering to property text in a draft title block?
or mapping to a PDM system?  if so, which?
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
with the help of this utility: export_Attr_mappings you export the mapping xml file (or Text), so I was wondering if I export and comment everything out, if it would turn the mapping off.
Greetings!
M
you will probably get more input from the folks on the TC ADmin forum...
https://community.plm.automation.siemens.com/t5/Teamcenter-Administrators-Forum/bd-p/Teamcenter-Admi...
Matt Johnson
Teamcenter 10.1.7
If you remove/comment  entries from your attribute mapping file, then reimport the edited mapping file, the attribute mapping will be removed from Teamcenter .
Honored Contributor
Honored Contributor
If you are trying to turn variables off that are showing up in a parts list, you can turn the expose variable check box off
How can you do this? Can you please send a screenshot?
Thx
Turning variables off in the parts list has nothing to do with turning attribute mapping off for SEEC to Teamcenter.
Honored Contributor
Honored Contributor
Screen shot attached. This prevent model information from being available in draft. Not sure how this relates to managed systems.
