How to use mirror function
Hi, I am trying to replicate a face of an aluminium profile. I would like to do the same thing for other corner of the this image, however i do not know to use any of the mirror tools to replicate instead of starting from scratch.
Thank you very much
Re: How to use mirror function
Hi there @Uzek,
The mirror needs an axis to be the line to mirror about, so you could sketch one......also, you may use the "Pattern" (circular) command, to achieve this too.
Solid Edge 2019 [MP8] Classic [x3 Seats - Cloud Enabled]
Hi, thank you for the prompt response, much appreciated.
