I have several STEP files that import blank into ST9 (MP3)
I am currently running ST6 & ST9, but during my testing I found that I am unable to succesffully import some STEP files.  I placed my templates into the C:\Program Files\Solid Edge ST9\Template\ANSI Inch folder and I least that got me a little further.  The tree structure looks good, but all of the file are 139kib (& blank).  I try showing all surfaces and that does not change anything.  What I'm I doing wrong?
Re: I have several STEP files that import blank into ST9 (MP3)
The method of importing steps has changed from ST7 to ST9..
Im ST7 you could choose between the "old"  and new beta method from what I remember in ST8 the new method was standard (as in ST9 now).
Take a look at
C:\Program Files\Solid Edge ST9\Preferences\Translators\STEP.INI
Open it and change
Import Multiple Bodies As Single Part file=On
to
Import Multiple Bodies As Single Part file=Off
Reboot and give it a try..
Hope this solves it for you.
Kind Regards,
Jan Bos
Emmen, The Netherlands
Solid Edge user since V3.5 and beta testing ST10
Honored Contributor
Honored Contributor
Surface bodies are no longer on by default. Could be the issue.
