I need help
Hi world.. I'm an Itallian boy and i need a help to endid my exams.
I 'm not able to dissect the central part of a connecting rod. Can anyone help me?
Re: I need help
Siemens Legend Siemens Legend
Siemens Legend
Ogy,
You've posted this to the "community Suggestions" forum, this question should go into one of the sub-forums.
what Product are you using?  SolidEdge or NX?  (I will move this to the correct forum)
Jerry
Jerry Sarfati
Siemens PLM Software
Re: I need help
Esteemed Contributor
@JerrySarfati ...by the attachment's file extension, this is likely a Solid Edge, call for help.
Further, the file is unable to be opened in my commercial SE, so is an Academic/Student version.
Re: I need help
I'm a university student and I'm using SolidEdge
JerrySarfati wrote:
Ogy,
Jerry
JerrySarfati wrote:
Ogy,
Jerry
Re: I need help
Ogy,
I suspect the problem might be, that you do not have the actual 3D models that the draft [2D drawing] sheet is referencing....as this will limit you in the ability to perform some functions to the views, such as making sections, as the view is derived from the model.
Is this what you're seeing....? [views with the broken line boarders]
Re: I need help
Now I've solved the problem, but I want to know, from the point of view of mechanical drawing, is it correct the representation of the connecting rod?Cattura.PNG
