INSERT COMPANY TEMPLATE
Dear Sir,
 How to insert company template,tital block in solid st6 draft file ?
and how to customize it as per requirement ?
plz reply
Re: INSERT COMPANY TEMPLATE
Esteemed Contributor
@yogi1432,
You need to show the "Background" sheet....go to the "View" tab, and toggle it ON.
Then you can modify it to how you want it...and then save [with your unique file name, if wanted] it to your "Template" folder in the Solid Edge installation directory. [usually...C:\Program Files\Solid Edge ST6\Template]
Most people make use if "Call Out" text to automate some/most of the identification fields.
