IS THERE A CHECK BOX TO ALLOW SELECTION OF RELATIONSHIP HANDLES?
Not applicable
I'm having same problem as Cedric had, I can't select Relations.
- They are displayed
- This is a problem regardless of whether "Maintain Relationships" is selected or
not
- Independant of what layer I'm on (tried all layers)
- Can select the elements themselves
- Quick pick only gives options of elements (e.g. two lines that meet and connect)
but not the Coincident relation.
Pretty sure this was never a problem with the 3D version, but it's driving me mad
as currently I'm having to delete the entity to remove a relation.
Please Help!!!!
-Andy.
www.continual-motion.com
Re: IS THERE A CHECK BOX TO ALLOW SELECTION OF RELATIONSHIP HANDLES?
Not applicable
When the Select Tool is active there is a Select Options filter button on
the left end of your ribbon bar. Select this and make sure Relationship
Handles is checked. I also like to have All Layers checked but that depends
on your workflow.
David
"Andy Southern" wrote in message
news:46b04f86$1@bbsnotes.ugs.com...
> selected or
> not
> connect)
> me mad
> Please Help!!!!
> -Andy.
Not applicable
LADIES AND GENTLEMEN: THIS GUY IS BRILLIANT:
Thanks Dave,
you've sorted it out (sort of)
The filter did have relation handles checked, but wasn't selecting.
I turned it off and then on again,
Now I can select (and delete) the Relation Handles.
I've also got it on "All layers" - I'm a 3d guy, so I prefer that to working on
specific layers.
Thanks for your help.
-AS
>on your workflow.
>David
