ISO view Smart dimension
I updgrade from ST6 to ST8 and now I cannot move the dimension from the center to the edge in the ISO view.
Please, if someone can help?
I have attached a screenshot.
Re: ISO view Smart dimension
I was able to verify the problem by using the distance between command vs. the smart dimension as seen in the video below:
But your specific issue can be trouble-shooted if you could share the draft file.
