Identical Parts
N/A
I've drawn 15 identical parts in 15 different locations and drawn one part to fit those parts. Is there a way of locking to each of the parts... without drawing each part?
Crousie
Re: Identical Parts
Esteemed Contributor
Not sure I follow what your looking to do exactly...but I'd think you'll need to use Inter Part copy.
Solid Edge ST10 [MP6] Classic [x2 seats]
Re: Identical Parts
Once again, Crousie, based on your last few videos and the parts shown within, I think you are misusing the assembly environment, and not understanding/using assembly relationships at all. You can draw ONE of each unique part, and use the assembly environment to add and position as many instances of that part as you want!
-Dylan Gondyke
Re: Identical Parts
I agree with Dylan. It appears you need to go through the tutorials and self-paced training found under Solid Edge's Help menu.
While we don't mind helping you, if you are going down an improper path to begin with, us trying to help you will just confuse everyone.
Production: ST10 MP5
Testing: SE 2019
