Imagination Engineer
Not applicable
someone has a import filter from Imagination Engineer at SolidEdge Free ?
The programs are the same, (Imagination was the old version of SE ) but I can not
find a filter for read the old file of Imagination with SE.
Thank for your help
Giuseppe
Re: Imagination Engineer
Not applicable
Guiseppe,
You must have had that software a long time. So much has changed from then
to now. Your best bet is to save as DXF or DWG and import into 2D Drafting.
Rick B.
