Import SE Templates into Teamcenter with Naming Rules active.
Gears Genius Gears Genius
Gears Genius
Hi experts,
Does anybody know if you can import the standard Solid Edge Templates into a Teamcenter database that has active Naming rules in place. If so, can you point me in the direction of the documentation.
ionman99
Re: Import SE Templates into Teamcenter with Naming Rules active.
Gears Genius
So I have gotten around the issue by temporarly unattaching the Naming Rule for the Item.item.id, and then running the supplied import template tool. and it all worked great.
Hope this helps anybody.
