Import a simple work from sketchup to solid edge
Hello, can anybody help me? I have a simple furniture work designed in sketchup and I send to a wood cut company to cut the pieces, they work with solid edge but they can't open the files that I send... how can I export or they import? Which will be the compatible archive to work 2 programs correctly together?
Betreff: Import a simple work from sketchup to solid edge
Hi @corpens
You can save Your model as IFC which can be opened by Solid Edge
Wolfgang
It seems stl and dxf/dwg can be other solution.
link
BR,
Imics
Hi @Imics
I would like to say, that STL is not the best preference due to the fact it will create a meshbody only,
which is course on one hand as well as large in size and poor in speed on the other.
Wolfgang
Re: Import a simple work from sketchup to solid edge
See this link for a tried and true way to get accurate CAD geometry out of SketchUp. You won't get solids but I think Solid Edge can import DWG, right?
@hawcad wrote:
Hi @Imics
My Friend,
It depends on complexity of geometry. Prior to 10 it was a difficult thing, but ST10 provides some nice tool to edit stl file like Reverse Engineering, Convergent modeling... I did some nice job with them...
If @corpens will share some pics about his model, I can give answer about solutions...
BR,
Imics
