Import pdf to sketch
Does anybody know a good way to import a 2D pdf into a model sketch? I've tried copying into MS Paint and saving that and the result is totally illegeble.
Using SE since V12, 2002
ST10 certified
Re: Import pdf to sketch
HI,
try this software Inscape (link). It should be freeware solution.
How it works is shown in video below. Impotant thing is that PDF must contain objects, scanned PDF will not work at all.
Source of this knowledge is from SEU2012 from Jason Wooden (PDF attached).
Once you have 2d geometry from PDF in 2D Draft environment, use "copy / paste" or "Create 3D command to move 2D geometry to 3D sketches.
Ota
(view in My Videos)
Here's another video on inkscape from @Imics
https://www.youtube.com/watch?v=KI-jwwVp_sQ
