Impossible d'imprimer
Not applicable
Bonjour,
Je n'arrive pas à imprimer, le bouton "Ok" reste grisé, quelque soit
l'imprimante selectionnée.
Please Help me!!!
3 REPLIES 3
Re: Impossible d'imprimer
Not applicable
Ok, in english
I can't print, the "Ok" button is disable, even if select a printer.
Stef
stef a écrit :
> Bonjour,
> Please Help me!!!
Not applicable
Stef,
Is this a problem that you only see with Solid Edge 2D Drafting? Can you
print from other products? Are you specifying the same printer as with other
products?
Rick B.
Not applicable
Yes, I can print with other products (like openoffice, etc...) with the
same printers.
Stef
Ricky Black a écrit :
> Stef,
> products?
> Rick B.
