In Assembly editor, PathFinder disappeared when I edit some part
Not applicable
I got a problem with ST4.
When I "edit" a part in Assembly, not "open in solidedge part", "PathFinder" disappeared.
I attached a pic.
Please help.
A lot thanks.
Zhenkai
Re: In Assembly editor, PathFinder disappeared when I edit some part
You can reopen it like this:
Not applicable
Thank you for your reply. But, but there is no pathfinder in it.
Not applicable
I have exactly the same problem.
I can no more edit the part in assembly. I am always obliged to "open in solidedge part", but it requires always to save before........
