In ST6 is it possible to turn off the steering wheel?
Recently updated to ST6 from ST5 and I do not like having the steering wheel appear every time a part is selected within an assembly.  Can this feature be turned off?  I found I could change its size but not eliminate it.
Yes, in the Select section of the Home ribbon, toggle off...
Yes, in the Select section of the Home ribbon, toggle off the command "Enable Component Select and Move".
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
