Index Ref.
Hi Guys,
I am having an Issue here with daft files with index reference.
every time i place a index reference for any file nothing shows up nor the material or the weight.
i have select the material as well.
Please advise where i am getting wrong.
Sam
Re: Index Ref.
Hi Sam,
It seems to be working as expected here....can you post pictures of what you're seeing, and maybe the call out text string being used also? Is this draft of a part or an assembly model??
Testing: Solid Edge 2019
Re: Index Ref.
Hi Sean,
Thanks for you reply,
Sending youa daft file of an assembly. have a look.
Sam
Re: Index Ref.
Hi Sam,
Without the assembly files to accompany the draft, it creates a disconnected draft, so none of the property text I add will not display any values pertinent to the parent file.
Your chassis assembly has mixed materials, so the "Index Reference" can't get a clear reading, at least where materials is concerned.
I think what you need to use here is the ,"From Graphic Connection" for item callouts, or "Named Reference" for assembly wide callouts.
NOTE: this doesn't account for configuration views of an assembly. [it'll display top level assy info]
Re: Index Ref.
Hi Sean,
Many tahnks for your quick reply.
I have tried what you said in your prevoius post, but it didn,t work Smiley Sad
Also all my material in the assembly is set to steel.
