Information loss when opening dwg file with Free2d
Not applicable
Hi
I'm having problems with opening a floorplan in dwg format. Some parts of the drawing seem to be missing like parts of the walls, some lines etc. When I open the file with Solid Edge Viewer everything is fine. Any ideas?
Marko
Re: Information loss when opening dwg file with Free2d
Not applicable
Are you viewing all layers?
Not applicable
Yep. All layers are visible. Seems like some of the blocks are missing after importing.
