Information on a bubble
Good Evening,
I would like information on how to- Building a bubble. I looked on You Tube nothing.
Thank You Very Much
Greg
Grundey writes:
Greg wishes to create a hemispherical shape with a planar flange around the edge...
Re: Information on a bubble
KennyG 2nd Gear
2nd Gear
What do you mean by "building a bubble"?
Production: ST10 MP3
Testing: SE 2019
I should of said drawing! I checked out You Tube for any videos on steps on
drawing a bubble nothing.
KennyG 2nd Gear
2nd Gear
I still don't know what you mean by "bubble"...
Testing: SE 2019
A bubble as in on top of a submarine for observation. 49.450 in. in radius,
2.357 in thickness with a bolt down flange 56.713.
I hope this will help
Thank You
Greg
SeanCresswell 2nd Gear
2nd Gear
Seems you have most of the information to make this already....radii & wall thickness. Try using a revolved protrusion.
Solid Edge ST10 [MP3] Classic [x2 seats]
- - - - - - - - - - - - - - - - - - - - - A bubble as in...
2nd Gear
Thank You
Greg
Hi Greg,
Seems you have most of the information to make this already....radii , flange size & wall thickness.
Try using a semi-circle as a revolved protrusion for the dome and circle prutrusion for the flange, then thin wall it. [see attached] [drawn to metric equivelant dimesions]
Re: - - - - - - - - - - - - - - - - - - - - - A bubble as in...
There isn't an attachment to this answer as so stated.
Thank You
Greg
2nd Gear
I see it.....
