Inquiry
N/A
I sure would like someone to explain to me the difference of Distance , Minimum distance, and Normal Distance. I seem to be having a hard time using those inquiry commands to get distances.
Re: Inquiry
N/A
Distance is going to give you the keypoint to keypoint distance in 3D space.
Minimum distance will give you the shortest distance between an element,
like a curve, and a point, or between a surface and a point.
Normal distance measures perpendicular to the selected face to a keypoint.
Hope This Helps,
Jason Inglis
The Charles Machine Works, Inc.
Ditch Witch
Perry, Oklahoma
