Insert Text
I am trying to insert text profile,into a laser cut part,  but when i put a letter  R in there,
the middle is going to fall out is there any way of being able to draw a profile into the letter
or can i edit,
Paul
Re: Insert Text
Esteemed Contributor
Hi Paul,
If you're stuck with the font used, then you would need to add a bar that crosses [joins] the internal part to the outer, for each instance....otherwise you can use the "Stencil" font that has this method built-in.
Re: Insert Text
It is a PAIN to try and use a nice font, then convert it to geometry so you can add your own webs to letters.
-Dylan Gondyke
Re: Insert Text
Especially painful when you need to edit the text, and the webs all fall appart....but, it's still the only way forward with non-stencil font types. *SIGH
Re: Insert Text
Gents's thanks again.
