Insert multiples holes?
Not applicable
I am using the free Solid Edge 2D Drafting V20. How do I insert multiple
holes (circles) into my print or 2D part? I can see how to insert the
feature one at a time, but if I have 100 of the same features in a certain
pattern, can I do that more simply?
Larry
Re: Insert multiples holes?
Not applicable
Larry,
Once you get the first object placed, you can use the Rectangular Pattern
and Circular Pattern commands. Select what you want to pattern. The pattern
commands will enable. Click on either Rectangular or Circular pattern.
Specify the inputs to create your pattern. Click Finish to create the
pattern.
Rick B.
