Inserting Parts
N/A
After the assy is visible... the parts going to the assy are way out of direction. http://screencast.com/t/6ZTDvOlbuqMA,
Do you just use the steering wheel or there is an easier way?
Crousie
Re: Inserting Parts
When inserting parts in the assembly, it is customary to use the assembly relationships to position the part.
Sent from my Motorola Electrify using Tapatalk 2
Production: ST10 MP6
Testing: SE 2019
