Instalacion ST7 student edition
Hola estoy intentando instalar esta version en mi ordenador y cuando la instalacion va casi 3/4 me sale un error que dice:
" no se pudo acceder al tiempo de ejecucion de VBScript para la accion personalizada."
le doy aceptar y me sale "el asistente se ha interrumpido anter de completar la instalacion de solidedge st7
Y la instalacion no sique.
Ayuda por favor !!!!!
Re: Instalacion ST7 student edition
Hello there,
Hard to diagnose from that information, but....first off, does you computer conform to the minimum system requirements to run Solid Edge ST7? [namely, Windows 7 or later, and must be 64bit]
Second, you might have an incomplete download.....try downloading again using a download manager, especially for slower connection speeds.
Once you have the new nearly 2GB file, right click on the ".exe" and choose "Run as Administrator"
Solid Edge ST10 [MP7] Classic [x2 seats]
tengo el windows7 home premium 64 bit
¿a que te refieres con un download manager?
OK, your PC should theroretically run Solid Edge.
Yes,...I recommend using a "download manager" for large monolithic files such as this one,....I use the one available for Google Chrome browser, but there are others, most are free.
Save your working download file & your license.....in case you change, or want to install on another, computer system.
ok
lo voy a descargar otra vez desde google chrome. A ver si asi funciona
Gracias!!
Lo he descargado desde google chrome y me sigue dando el mismo error
Avisame si te puedo informar de algo mas para que me ayudes
Gracias.
instalacionst7 wrote:
I've downloaded from google chrome and still gives me the same error
Notify me if I can inform you of something else to help me
Thank You.
Did you also install the "Chrono" download manager, for Chrome?
