Install Free 2D on Drive D: ?
Not applicable
the Software (Free 2D) will only install on Drive C: (without Question)
On my Computer are only the Drive D:
How can i install the Software on Drive D: ?
Greets
Christian
PS: Sorry for my bad english ;o)
Re: Install Free 2D on Drive D: ?
Not applicable
The installation software is expecting a drive called 'C:' You are not
required to install the software on the 'C:' drive, it just needs to be
there.
When you install you can specify where your to install the software. In your
case this is on the 'D:' drive. To get around the issue where there is not a
'C:' drive, others have been successful by connecting a flash drive to the
computer. Ensure that the name of the flash drive is 'C:'. You still need to
specify that the software goes on the 'D:' drive. When the software prompts
for the location to install, make sure it still has the full path. All you
need to do is to change 'C' to 'D' in the path shown.
Rick B.
Not applicable
Great !
That its....
Thanks alot...
Greets
Christian
