Install script is missing
Not applicable
Tried several times to load this software. I get the msg. Install Script is missing Installscript.msi. I tried downloading it from Microsoft and it still gives me the same error.
I'm at the verge of abandoning this software. Can someone help me out?
Thanks.
Dominik
Re: Install script is missing
Not applicable
Dominik,
I did not know what would cause this problem with install.
Did you try downloading the software again?
The executable may be corrupt.
What operating system are you running on? (XP, Vista, etc.)
Rick B.
