Installing Solid Edge Free 2D
N/A
I was able to download the software to my machine without error. When I tried to
install it with InstallShield, it unsuccessfully loaded ended with error message:
Install Shield 1607
Unable to install installshield scripting runtime
Any help is appreciated.
Jerry
Re: Installing Solid Edge Free 2D
N/A
Jerry,
This is an error being reported from Install Shield, which is a component
Solid Edge uses for installation.
I searched for this error with Google and found the following. You can also
search and find information about this error.
I found the link below. It gives instructions that may help solve the
problem.
http://consumerdocs.installshield.com/selfservice/viewContent.do?externalId=Q108340&sliceId=1
Rick B.
