Insulation, Concrete and othe architectural symbols?
Not applicable
I've found the concrete symbols in SE2d, but I'm having trouble getting the insulation
symbol (like a load of "S" or a miandering figure 8 between two parallel lines).
Are there any architectural drawing symbols anywhere?
-Andy.
www.continual-motion.com
6 REPLIES 6
Re: Insulation, Concrete and othe architectural symbols?
Not applicable
Andy,
I am guessing that you are talking about a hatch-fill when you say concrete
symbol. Currently all hatch patterns are derived from linear segments. So
the "S" pattern for insulation is currently not available.
Rick B.
Not applicable
Rick,
I thought maybe it was the other way around, that the sections were derived from
2D work somewhere, as the concrete fill appeared to be a random triangular pattern.
i recognise that the insulation would have been a linear (1d ) pattern, not a 2d
pattern. Is there any way to change a line font to something a little more complex?
or do you have any recomendations as to how to deal with this?
I'm currently thinking a few different width symbols and then use the pattern command
for a linear pattern of them.
-Andy.
"Rick B." wrote:
>Andy,
>Regards,
>Rick B.
Not applicable
Andy,
The triangular pattern you see is still a sequence of linear line segments
with different gaps and at different angles. You can see this by going to
Format-Style and modifying the Hatch style (Not the fill style) for that
type. The fill style uses a hatch pattern style of the same name to produce
the pattern.
We have been investigating implementing a user defined pattern type of hatch
where you could create your own geometry of any shape. This is future and
has no implementation schedule at this time.
Rick B.
Not applicable
Rick,
That would be really good if we could do that.
Definitely one for my wish list.
Possibly below "parametric patterning in 2D": where the number of occurances of
a pattern could be controlled via the "variable Table".
Is there a 2DWishList board/feedback channel for us 2d users to say what we'd really
love to see?
-Andy.
>Regards,
>Rick B.
Not applicable
Andy,
Please use this newsgroup to voice any enhancements you would like to see in
2D Drafting. A customer that has purchased Solid Edge has access to Solid
Edge support where they submit enhancement requests and log problems.
Rick B.
Any progress on a fill pattern for insulation? The continuous 'S' type of thing??
