Invalid license
I installed SE but when I start, it says invalid license.
Could you please issue a new license ?
askhiste@oakland.edu
Hostname : teamcenter-Cli
Please let me know if you need more details.
Atul K
7 REPLIES 7
Re: Invalid license
Hi Atul,
You have received an email with a licence text, something like;
INCREMENT solidedgeacademic selmd 106.0 etc. etc. etc.
Open this textfile with notepad select all of the text and copy it (Ctrl-A
than Ctrl-C) than close notepad
Open the license.dat textfile located in C:\Program Files (x86)\Solid Edge
ST6\Preferences with notepad
Select all the text (Ctrl-A) and delete it, than paste the text from the
licencefile you received in in (Ctrl-V) and save the file.
You now have created the correct license.dat in the correct location.
Start Solid Edge it should work.
Alternative, save the txt document you recieved somewhere on your pc, but
rename the extention from .txt to .dat
Go Via Start Button/Solid Edge ST6/licensing/license utility and choose "I
have a license file" browse the the location were you store the license.dat
created above.
Succes, and have fun with this wunderfull design software.
Jan Bos
The Netherlands
"askhiste@oakland.edu"
wrote in message
news:askhisteoakland.edu.64vk4b@noreply.bbs.industrysoftware.automation.siemens.com...
> Hi,
> Thanks,
> Atul K
> askhiste@oakland.edu's Profile:
> https://bbs.industrysoftware.automation.siemens.com/vbulletin/member.php?userid=636687
> View this thread:
> https://bbs.industrysoftware.automation.siemens.com/vbulletin/showthread.php?t=53484
Re: Invalid license
Not applicable
I could install ST6 successfully , but i do not have any attachment regarding License , help me how to go ahead.
Re: Invalid license
Not applicable
I am not received email with a license text, something like;
so how?
what I do?
Re: Invalid license
Check your Junk e-mail folder or re-register.
http://Grundey.blogspot.com
Re: Invalid license
Not applicable
oce...
thanks very much...
Re: Invalid license
Not applicable
i am having problem with license.
system clock has been set back
error: -88309
pl provide solution to continue
Re: Invalid license
Not applicable
i dont have solid edge licens. i turn pc clock pack and i cant use any more this licens.. how i can get new???
