Inventor Part, Assembly Documents
Not applicable
Is Autodesk Inventor needed to operate Inventor Part, Assy... and how to send parts to this document from the standard views.
Crousie
Re: Inventor Part, Assembly Documents
I believe you just need to install the Inventor Viewer to use the import. Inventor files must be V6 or higher.
http://Grundey.blogspot.com
