Irregular pattern feature?
i want to pattern a cut feature to those dimensions, but the pattern feature only allows equally spaced patterns. whats the best way to do it? would i have to add all the holes in the sketch?
MagRiz
(ST9 User Est 01.18)
7 REPLIES 7
Betreff: Irregular pattern feature?
Hi @MagRiz
either You use a "Pattern By Table" feature or a "Duplicate Feature" or as it looks like here, YOu also can model a piece of Your part only followed by a final mirror body to get the full one.
Wolfgang
@hawcad
Hi, just an update on this. I understand how the table works but not the duplicate feature. i dont understand how that works. do i need to create a separate reference sketch with points where i want the holes?
can you create video to help me out please?
MagRiz
Hi @MagRiz
for Duplicate Features in an ordered part, the best IMHO is to create a sketch where You place a small block according to Your wanted positions and orientations.
And this block can be used for referenceing the duplicate positions.
I believe that there should be an example in the ST9 "What's New?" and/or in the help pages from the Duplicate Feature
Wolfgang
@hawcad
what do you mean by block?
what kind of sketch will it be, made from lines or ref lines?
MagRiz
HI @MagRiz
no, a block is a 2D feature (from Autocad) and used in 2D draft for years (draft header blcok, etc.)
Since ST9 You can use a block in a part sketch too.
And a block IMHO is the easiset place holder for a Duplicate Feature function.
Wolfgang
Hi @MagRiz
see attached video, this should explain everything!
(view in My Videos)
Wolfgang
Hi @MagRiz
PS.: instead of using a reference block for placing the Duplicate Features You also can use coordinate systems.
But, then You have to click every single coordinate system wheer You want a copy -
rather than using the "Select All Matching References"
So IMHO the selection of the copy places takes more work and the creation of the CS also needs longer and is not as visible as a sketch
Wolfgang
