Is Solid Edge Down
Good Morning,
I would like to know if SE is down? I went to get on this morning I am getting nothing.
Thanks a Million
Greg
What do you mean by "is solid edge down?" Do you mean the...
What do you mean by "is solid edge down?" Do you mean the SE install on your PC or do you mean the GTAC site?
Terry Tyson
Software Automation Designer
Re: What do you mean by "is solid edge down?" Do you mean the...
I mean is SE down for repairs!
Greg,
Again, This question does not communicate enough about what you are truly trying to inquire about.
Are you asking about software installed locally, GTAC, BBSnotes, your license server?
Please give this question some context... but to answer directly - NO, SE is not down for repairs.
Matt Johnson
Application Engineer
Ally PLM Solutions
matt.johnson@allyplm.com
http://allyplm.com/
