Is it possible to change Part/Assembly template from different language?
Hi Everyone,
Have anyone experiencing receiving part/assembly with diferent language seting?
is it possible to change it to our template/our Language seting?
Thanks & Rgrds
Destian
Betreff: Is it possible to change Part/Assembly template from different language?
there is a macro withinthe Custom directory called "ChangeLocal" which IMHo should do this.
I have used this 15 years ago to convert US files to European units etc.
Give it a try!
Wolfgang
Wolfgang
Hi Wolfgang,
Great to know that SE may do that.And thank you for your answer.
I have tried it just now. unfortunately i didn't find any changes on the Part UI. does this macro also work to change the language it self?
Thanks & rgrds
@hawcad wrote:
Give it a try!
Wolfgang
