Is it possible to generate a Rectangle Grid in Solid Edge
I was just wondering if there is a way to generate a grid in sketch mode that is made up of rectangular boxes instead of squares? Can you have input different x and y values?
Sam
Re: Is it possible to generate a Rectangle Grid in Solid Edge
I can't find it in ST7.
Neither can I find a possibility to make a grid for isometric drawing.
There is a shortcut for nearly all the grid options, but not for on/off...
#unfinishedJob
Solid Edge ST10 & AutoCAD 2019 user
No, it is not possible.
Perhaps if you send a request for it they can change it?
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
