Is there a maximum file size
Not applicable
Hi
I was wondering if there is a maximum file size that SE2D can handle or is it limited by the hardware of my computer.
Currently using ST4, upgrading to ST5 at the end of this current drawing.
Pete
Re: Is there a maximum file size
Limited by your PC. There are many consideration to handling large files and you need to define what you mean by "large files", but in all cases it is a limitation imposed by your hardware.
Production: SE 2019 MP4, Testing: SE 2020
http://Grundey.blogspot.com
