Is there any way to find pattern count in fill pattern
Hi
      Let me know is there any way to find the pattern count after creating fill pattern in ST10 (not manual counting)
5 REPLIES 5
Betreff: Is there any way to find pattern count in fill pattern
Hi @COLPUGAZH
only if this is a hole feature.
If this is the case, then You can use the Hole Count feature of SE.
See picture, and use the %QC (Quantity Coplanar) to show the number of hole counts.
Wolfgang
Let me know if it is in Rectangular pocket is it possible to find this QC count?......
Hi @COLPUGAZH
the hole pattern You see here is a rectangular pattern of one hole.
For the Quantity thee is no rule how they are created.
Only the number of holes is counted, but not depended on the creation method.
Wolfgang
Please tell at where this option is available......
Hi @COLPUGAZH
as shown in the pciture above, You can use the call out text %QC or %QP or %QA to get the number of Coplanar, Parallel or All holes of a type
And You can use this in the part document and/or the draft
Wolfgang
