Is this software render compatible?
N/A
I like to use google sketchup, and AutoCAD 2010 for models, and after words I like to render the models with KeyShot2... What I am wondering is if I will be able to render my models with Keyshot2 and Solid Edge Student Edition?
Re: Is this software render compatible?
N/A
Yes the software has rendering in the student version. The student version is ST4 and as of today from the Keyshot web site they are only supporting ST3 and prior versions. You may want to post a tech question to Keyshot.
Siemens Builder Siemens Builder
Siemens Builder
I asked @thomasteger VP of Marketing for KeyShot when they will have support for Solid Edge ST4. I will let you know what he says.
Also check out Mark Burhop's Blog Post on Key Shot and Solid Edge. Even though it's ST3, it's worth the read:
http://blog.industrysoftware.automation.siemens.com/blog/2010/09/30/a-look-at-keyshot-2-1-and-suppor...
Susan, could you please answer my emails or PM? It's really important!
