Issue with "close all" command going unfit in preview for all saved files
If I use save all and close all commands in solid edge drafted files, going unfit in the "preview pane" window and please tell me anyone how overcome this issue.
Re: Issue with "close all" command going unfit in preview for all saved files
You must Fit All before Save All, Close All
Hi thushar thanks for the reply:-)
1. There is no "fit all" command in soliedge if it's let me know
2. I used Fit all files one by one and then clicked "save all" command and "close all"
3. In windows "Preview pane"(ref attachment) I am getting cropped preview expect the first closed file
4.  The problem is > draft file window get minimize(re open the drafted file we'll get the issue) before save all if we use the close all command
5. And I hope you'll be understand
6. For better understanding need to be experience
7. Conclusion is "the problem is not yet been resolved"
