Issue with simulation
Good afternoon,
I`ve met with an issue - on SE ST8 Simulation is not working. I`ve tried different shapes, force values, etc. It`s still not working. You can find a screenshot below.
Does anyone have any ideas or advices?
P.S. I have a Russian version of SE ST8. On the picture you can find a translation (written with red color).
6 REPLIES 6
Re: Issue with simulation
Did you look at the Nastran Log?
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
Yes, I did. It`s totally empty.
I'm assuming this happens at the "solve" step.  How much RAM do you have on the machine, and is it a big part with lots of facets or is it on a simple part?
Might also be a installation problem if SE was not installed using Run As Administrator.
Aside from that, I have no idea.
You are totally right - it happens at he "solve" step. I have 8 Gb RAM on my computer and it was enough for SE ST7. On the picture there is a common part like cube.
I`ll reinstall SE using Run As Administrator.
Thank you Grundey!
Your advice helped me and now it`s working!
Great!  Glad you got it working.
