Issues opening step file in asm format.
Dear Sirs,
I have a problem in opening step files in asm format.
When I open the step file in solidedge ".asm"  format, with  "ISO metric assembly" template. units of ".asm" i.e. assembly file is showning in mm. (millimeter) and indivisual part file (.par) units showing in "inches."
so if i want to both (.asm & .par) files unit in millimeter, what setting to be done?
Pl. help.
Somnath
