Just FYI: Insert Assembly Copy bug
Discovered a bug in ST8 MP5 & 6 having to do with Insert Assembly Copy. It errs out while processing.
GTAC agrees. Although the tech said he only had to roll back to MP5. I had to roll back to MP4.
Not a concern if you don't use IAC. I'm sure it will be fixed in MP7.
Bruce Shand
Re: Just FYI: Insert Assembly Copy bug
@bshand Thanks for the heads up!
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
