Keep track / log of modification?
Hello Users,
I have a doubt, is there any way to keep a log og the design process, to keep a track of the steps that I took to make a design. For example in Rhino, you can see the historial?
So if you can export txt or something of the procedure, would be helpful.
Regards.
Re: Keep track / log of modification?
Hi there @AmanRa,
Does the "Feature Playback" tab do what you want?
https://docs.plm.automation.siemens.com/tdoc/se/109/se_help/#uidSmiley Tonguelybck1d
