KeyShot 5.1 Available!
https://www.keyshot.com/2014/keyshot-5-1-now-available/
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
5 REPLIES 5
Re: KeyShot 5.1 Available!
Says the guy with ST6. You know you want to upgrade. You know it.
____________________________________
--Scott Wertel, P.E.
DO NOT UPDATE KEYSHOT!!
I done the update thorugh Keyshot, and now I have a trial version of Keyshot!  It is not recognizing my Solid Edge keyshot license that is installed with ST7
Owner: Scott Lester Drafting & Design
Designer: Rotork Instuments
I updated mine and it still works fine as KeyShot Solid Edge although I updated it by downloading the update, not using the Check for Updates link in Help.
I'm running ST7 on my machine, but it's ST6 for production still...
Gotcha. I was able to fix my issue. I just had to go reload the .lic file from Program files in the ST7 folder.
